https://www.amazon.co.uk/Wireless-Connections-UK-Archer-VR900/dp/B01132GCP0
the wifi is much, much better. Also it's far more configurable if that interests you. It doesn't drop out randomly either which is why most people replace the HH5 as far as anecdotes suggest.
Edit to say: The wifi signal on the TP link is actually much stronger than the HH5 even when it was working.
Mine would drop the WAN connection regularly as well as being poor at wifi and I'm a control freak
I also saved a lot of money switching from BT to Plusnet when my minimum term expired on BT Infinity. Plusnet resell the BT service so quality-wise you're getting the same thing. But the Plusnet router, while looking just like the HomeHub 5 is even worse - which is what prompted me to buy the TP-Link router. You can save even more money on Plusnet by participating in their referrals scheme.
Oddly enough, anything wrong with the newer BT Smart Hub? It seems to be well reviewed but that's not allowing for long term use.
Feedback
I haven't tried connecting via cable. Not even sure if I have a cable!
https://www.amazon.co.uk/AVM-FRITZ-Box-International-Integrated/dp/B00H3IC3FC
It is ridiculously good- but for £200 it should be.
Changed the settings so that there is now a choice of connecting to either 2.4ghz or 5ghz - I connect using 2.4ghz on the mac and no more connection dropouts!
I can't the blame the mac, it's doing really well to say I bought it in 2009 and still use it for live shows. it's just a niggle.
Maybe i got lucky maybe your all unlucky it just maybe mine now dies and I don't get to finish this po....
