Also, you may get a boost in treble when the pedals are on compared to when they are off. I had this with the Flashback and Carbon Copy. A buffer can help, but I found that with the buffer there was a general brightening of the tone all the time.
I spoke with the amp builders and they blamed the pedals!
Mesa and Boss are not particularly bad for this, but there is a definite problem with some - a DD3 in the loop of a Rectoverb for example. I haven't tried a MkIV with pedals in the loop so I can't say - they're such different amp circuits that there's no way of knowing if the level is similar, even though both are Mesas. The problem can be fairly slight - I fixed it in the Rectoverb by dropping the level only by about half.
I think Mesa may have taken note of a lot of criticism of their FX loops recently - they always used to use a parallel loop with crude passive mixing which was a nightmare for any digital effect that ran the dry path through the digital domain, causing an unavoidable latency-based tone suck - most new models seem to use series loops, so it wouldn't surprise me if the 25 is better for level too.
Putting something in the loop before the pedal, like a volume pedal or a volume box, can bring the hot level down so the pedal works, but then you have to rely on being able to bring the power amp volume back up after the pedal to compensate.
Hopefully your loop has vols for the send and the return, in which case lower the send vol and raise the return vol
