It's fast and it can daisy chain.
USB 3
High power capacity (ie you can charge a laptop through the connector)
Displayport ++
PCI-E
My laptops both have it - with an HDMI or DisplayPort adaptor it gets higher frame rates than the onboard HDMI... The docks are the interesting bit though - with just one cable you get power, connections to displays and mouse and keyboard.
I've got it on my macbook but never used it because of price. A 4tb drive is about £300, whereas I got a USB 3 one for £110. Not worth it to me for the extra speed.
The other thing I got asked about was 16GB of RAM or 32GB
I'm not very up to date with IT, so I appreciate the help!
As for 16GB or 32GB, more is better if you're using power demanding applications, such as design and music software. Having said that, not a great deal will use more than 8GB of memory anyway.
job done, forget and I know I won't need more.
Unless you're buying an apple, in which case it's practically double the price it actually should retail for - an upgrade from 8gb to 32gb will cost a good couple of hundred quid in an imac...
Luckily, for some macs at least, you can upgrade the ram yourself by buying the correct ram at retail for half the cost.
Two 16gb ram sticks are about £240 at retail.
Upgrade an imac to 32gb ram is an extra £540... So they charge over double the current going rate of ram.
USB-C is very neat, especially for laptops, but I don't think you "need" it. Most places still let you plug in via VGA, after all...
I wish usb-c was being taken up faster, it'd be great on dslr's, too.
