Folk using Helix live - how are you protecting it?
TimmyOTimmyO Frets: 7693
If things go according to plan mine will start leaving the house at last.
I've not plumped for a bag/backpack/board/case so far, and wondering how folks are faring when playing out.
My main concern is the connections on the rear getting stepped on - I guess a flat live-in board would sort that.
Although for transporting I think I'd prefer the Gator or Novation padded bags.
Has anyone used or seen pics of any sort of doohickey that would protect that area?
Red ones are better.
  • simonksimonk Frets: 1467
    I use the Helix backpack for transportation - expensive maybe but a well thought out quality item.
    For on stage protection I just have my monitor tucked up to the rear of the Helix.
  • robinbowesrobinbowes Frets: 3069
    I went for the Helix Rack for this very reason. It's nicely protected in a flightcase at the back of the stage with only the controller at the front. I will be putting the controller in a case too, along with a couple of expression pedals.
    R.
  • JalapenoJalapeno Frets: 6408
    Just a thought - a hard case with sockets in the case wall connected to the Helix.
    Feedback
    I do the same (I use the L2 so there is a fair amount of overhang)
    I have also used a temple board and routed the outputs to a panel on the side of the board
  • TimmyOTimmyO Frets: 7693
    with the external ones on the side perhaps, rather than rear? Not a bad idea...
    edited May 2017
    Side/Rear whatever.  Or a connection block inside separate from the Helix.  When I had my monster boards I drilled holes in the side, had them very clearly labelled and connected to those - made life simpler.
    Feedback
    I'm using the Thomann flight case.
    It never leaves the base part even at home. There's a 2" bit at the back behind the helix where the wireless receiver lives. That means 2 cables going out - power and 1/4 inch to cab - both are protected by the space at the back of the case.
  • sw67sw67 Frets: 236
    I am getting a helix but for home use only. Had a drunken oaf fall backwards and land right on top of my pedals. He then proceeded to use my les paul on its stand to pull himself up. in the end i lost it and stopped to drag him off my gear followed by a swift kick. Worst venue ever and not one i will hurry back to
    Got a Novation 25 keyboard bag. It fits perfectly and is portable.
  • VaiaiVaiai Frets: 530
    Got mine on a Pedaltrain 2 with softcase. We use a dummy monitor for protection! I have the FX8 just now so it's the same problem - cables out the back and expensive unit with drunk ppl all around
    Tempted to make a simple nano board for those sorts of gigs...
    Do you not find the Pedaltrain too tall??
  • stratman3142stratman3142 Frets: 2224
    edited May 2017
    I haven't used it live yet, but it fits in my old pedal train case.
    I've also fitted a screen protector which I ordered from the US at the site below. It arrived pretty quickly.
    https://glenndelaune.com/patch downloads.htm
    It's not a competition.
    I've got my eye on that if I go the bag route - do you have that one? What's the padding like?
    It's when it's on the floor I was thinking of
    You should def. look at the thomann flightcase for on the floor protection.....
    I don't use anything for on the floor. But for transport the bag is great. The padding is fine!
  • SassafrasSassafras Frets: 30320
    Image result for Snarling Rottweiler
  • RolandRoland Frets: 8840
    A live-in board with removable top has always been my choice. It can also hold the cables already plugged in.
