This is what your after!
Whilst this electric shower uses mains cold water, the water comes from a tank which is installed in the loft in the block of flats where I live. This pressure is powerful enough to give a strong spray, but is not as powerful as a Power Shower driven by an electric pump.
Let me explain why I changed the head. The front of most heads rotate to change the spray pattern, Eventually, they leak between the rotating part and the main body as the rubber gasket gives way, and spray water in all directions from the side at random. Quite annoying.
I replaced the Triton head with this 4-Function Croydex head from Robert Dyas (also sold in Tesco's superstores). Actually, I think mine is a chrome 5-Function head.
http://www.robertdyas.co.uk/search/go?w=five+function+eco+shower+head
The Croydex head is designed differently, in that the gap between the rotating part and the main body is at the front. If it starts to leak (which mine isn't doing, and I've had it for about 8 months), the spray will emerge from the front!!!
I found it funny as the restrictor is meant to make it more eco but when it was in I had to have the shower in normal mode, now with it out the pressure is good enough to use the shower in eco mode.
Changing the shower head will make very little difference, even if you go to a smaller head, thereby squeezing the water through a smaller space.
Just because you're paranoid, don't mean they're not after youThe answer is big single function shower, high above your heard, let gravity do it's thing.
https://www.ecocamel.com/education/why-does-my-shower-have-low-water-pressure?gclid=CP248riDhNQCFRUTGwoddzoNnw
Instagram
