Remind me, what's the problem with the effects loop on the VC range? Is it that they are neither fully serial nor parallel, and thereby nigh on unusable?
I have the option of a VC15 and 2x10 extension cab for a great price, and uncommonly near to where I live, but I use effects loops a lot and so thought I'd best re-investigate this issue before taking the plunge.
Apparently it's a simple mod to remove a resister and convert this to series (although I think you then have to use a patch lead between send/return if the loop is not in use.
I never got round to trying this on my own VC15 but I did bookmark a couple of links about it ...
http://www.laney-posse.co.uk/theposse/viewtopic.php?f=1&t=824
http://www.tdpri.com/forum/amp-central-station/40443-laney-vc15.html
http://music-electronics-forum.com/t26753/
[edit] I've just checked those links and there's nothing specific (but one doesn't work - that's probably the one with the info). However, before I bought my VC15 I emailed Laney support about whether this mod is possible and this is the reply I received ..
