Not all drive pedals sound good with all valve amps. Worth checking out the That Pedal Show YouTube video where they match drive pedals with the right amp.
Very interesting. I now have no clue what drive pedal would suit my amp. Expensive trial and error !
I have one and asked Burgs to do a demo, which he kindly obliged
If you're playing at lower volume, then something like a Plexi in a box is a good option - but I have no personal experience of the Carl Martin. The best such pedal I have ever played is the JHS Andy Timmons overdrive, which is a little more modern rock-orientated, but it can do a good classic rock tone. Also has a "headroom" switch, which has three settings from quieter and more saturated, to louder and less saturated. The latter is the best sound, IME. I don't own one but I would like to.
My favourite overdrive out of my own ones is the Nobels ODR-1, which several others on here will recommend too. Not your usual mid-boost Tube Screamer-voiced overdrive, far more of a ballsy rock sound on its own. Would probably sound great for classic rock - dirt cheap too. Can't fault mine, other than that with the drive turned up you sometimes have to do some dialling in or it can get too bassy. But I tend to set mine for lower gain, so it's not such an issue.
To distil it down: you set your amp just where it's at break up, maybe even a little shy of that, and your OD kicks it over.
And set the OD pedal's output basically at the same level as your guitar's input or just a smidgeon more. But not a ton more.
The rest is down to what you like.
Like @Bucket I love the Nobels OD-1 but it doesn't have the sound I identify with Jimmy Page (which I always think of as thin and scratchy) AND the combination of OD pedal and amp is weirdly idiosyncratic too. (When I changed from Marshall valve to Orange SS I had to change OD from Ibanez TS to Nobels OD-1).
Inevitably: buy pedals; flog 'em.
Solid drive pedal, more gain than i was expecting but very usable.
