They look crap, but they sound better imo than the mg-dfx (which is what I had - still usable! But yes, it did break).
There is less gain available on the carbon fibre, and a less nasal midrange sound. It is a decent amp. Overshadowed massively by the orange crush pro, though, which don't sound "good for the money" so much as "really good full stop". They still sound solid state, but in a great way.
Tbh I used to gig with a guy playing a mode four head and he got a great sound out of it.
He was using a Les Paul in B tho.
I liked the 100 watt, but the FX loop is crap on it.
The 60 watt only sounded good at gig level volumes, but had this really transparent FX loop.
Aside from the motherboard issues which I'm sure are well documented. The footswitch was the real issue. I went through 2 a year without fail.
Its easy for the tech heads on here to knock it. But the head had the same reliability as my Jubilee 2553 combo.
But then I bought a TSL122 combo used that spent its entire life being repaired. So the tech guys have a point.
I guess the JVM is a better option.
Mine was buggered too - I replaced the cable with a much higher quality type and the plug with a metal-cased one. While I was at it I also changed the LEDs for something much more logical than the five reds it comes with - green for clean, orange for crunch like the amp, green for reverb, leaving the reds for lead and FX. Although being able to switch the FX loop on and off is not really a great idea since it causes a volume drop…
I would sell the footswitch if anyone needs an upgraded replacement for less than Marshall want for another crap one.
It had some great sounds available (lots of bad ones as well!).
But they very quickly got a reputation for, er, exploding
ive owned other Marshall models since then.
Everyone I've heard gig a DSL or TSL has sounded at least pretty good too.
It just shows that spending too much time on this forum can ruin or deprive you of enjoyment of a lot of gear.
I don't deny that they might sound good to some people (although that's also possibly a minority opinion), but it's actually a good thing if the 'accepted wisdom' is spread far and wide on things like this, since it will save people from spending their hard-earned money on something which then costs a fortune to repair or they end up just writing off.
Marshall stopped making them after only a very short time, and even the bands who endorsed them stopped using them - if something is that unreliable, it isn't even worth having for free. Just an abomination of a design.
I've only had a couple of Mode 4s in for repair, but from memory neither was a cheap repair.
I've repaired a lot of DSL / TSLs.
Regarding internet "wisdom" on amp reliability / build quality, then I suspect that people who repair amps full time for a living are good source of information.
Otherwise we are using the "my grandad smoked 40 a day and lived until 95" type of anecdotal evidence based on an example of one.
It's that kind of wilful ignorance and disdain for the customer that would make me refuse to buy a Marshall amp, even if I liked the sound it makes.
