Recommend a S.S Amp for my Bandmate Please
BellycasterBellycaster Frets: 5879
edited June 2017 in Amps
He's asked for my advice and doesn't really want to go with valves, let's say Sub £500 for the amp( COMBO).
No Modelling(Cube, Katana, Code, Vox Equiv etc), just a straight 2 or 3 channel SS Amp. I'm thinking Orange Crush 60 is a winner. Can you get a dedicated footswitch with this amp?
There may be more makes and models though? Laney or Something else???????? I've only had a quick look, but solid state is not my expertise.
The amp is for gigging so simple is best...ie: Clean sound to Driven sound that you can match volume on easily. He may also use a pedal or two in front.
Thanks.
Only a Fool Would Say That.
  • ICBMICBM Frets: 72862
    Orange Crush 60 or 120
    Peavey Bandit or Special
    Fender Champion 100
  • BeexterBeexter Frets: 617
    Tech21 Trademark 60
  • martmart Frets: 5205
    Beexter said:
    Tech21 Trademark 60
    Lovely amps, but ime they won't do:
    ....Clean sound to Driven sound that you can match volume on easily. ...
  • professorbenprofessorben Frets: 5105
    Bandit and a pedal.
    Winner
  • BabonesBabones Frets: 1207
    Secondhand Marshall VS100. It has a preamp tube, but otherwise low maintenance. I never had to change the one I owned. Loud enough to gig for sure.
  • JayGeeJayGee Frets: 1280
    To all intents and purposes the Katana is a straight 4 channel (but you don't have to use the extra one if you don't want to) SS amp. Yes it's modeling technology under the hood, but in use it's very well hidden.
  • EricTheWearyEricTheWeary Frets: 16309
    Koch Jupiter 45. A little bit over budget but who doesn't like a little Koch?
  • ennspekennspek Frets: 1626
    Blues cube artist.
  • KebabkidKebabkid Frets: 3340
    Another plus one for the Roland Blues Cube Artist (used as new might be outside his budget and the footswitch is extra).
    Shame he doesn't want modelling J as the Boss Katana 100 gets good reviews.
  • darthed1981darthed1981 Frets: 12177
    Yeah - I thought that as well, the Katana 100 is an obvious candidate and would leave budget for a backup amp as well, or some pedals!
    What is the reason for the prejudice against digital and valve amps?
    Isn't the blues cube a modeller, ie, digital amp?
    If the insistence is not digital, probably got to be a peavey bandit, peavey special (!) or a orange crush Pro.
  • paulphoenixpaulphoenix Frets: 141
    i'll admit I'm a little out of touch with the current solid state products out there but,  if i had to get a SS amp i think i would get a blackstar ID**TVP (not the ID:Core).
    a few years ago i was "this" close to getting one before i joined the valve appreciation society.
    I thought the Blues Cube was SS modelling ( if there is such a thing)rather than digital? Apart from being a bit over budget it ticks the other boxes anyway.
  • HAL9000HAL9000 Frets: 9788
    I think it's a digital amp, but uses plug in modules to access different models to make it seem more an analogue, traditional experience. I think, if they actually were solid state circuitry, it would be too costly to produce them versus a simple software unlock.
    Mind, that's just my speculation, could be way out.
    I'd not rule out a digital modeller anyway. The Katana amps sound great up loud. I'd take one of those over an orange crush probably.
    Ahh, I remember being quite excited about the arrival of the Blues Cube and then playing one for ten minutes and experiencing a huge rush of dissapointment so I've not kept up since. I know they have those optional tone modules so that must be digital.
    For straight up solid state I'd go for Peavey.
  • BucketBucket Frets: 7751
    Bandit.
  • BellycasterBellycaster Frets: 5879
    Bucket said:
    Bandit.
    There's no need for that, I only asked a simple question :(
  • simonksimonk Frets: 1467
    Technically hybrids as they have a valve preamp. Cracking sounding amps though, loved my Studiotone.
    I'd go with a Blues Cube Stage/Artist - I thought the latest gen were all analogue.
