Ben8010Ben8010 Frets: 150
edited July 2021 in FX
  • peteripeteri Frets: 1283
    Mojo Hand Rook.
    I have one and it's not going anywhere! More versatile gain and the tone controls are great - bass and treble.
    Good value too. Funny before I had the Rook Royale and didn't care for it - but the original is great.
    Another one (will cost a bit more) is the Wampler Clarksdale
  • steersteer Frets: 1188
    Where is the guy who answers Rat to every single question when you need him?
  • thomasw88thomasw88 Frets: 2326
    Nobels ODR-1 will give you exactly what you want.
    or spend large and get Strymon sunset and never want for an overdrive pedal again.
    If it's a bit more bass you want and a fuller sound: Way Huge Pork Loin.
    Not particularly cheap though unless you find it 2nd hand.
  • JezWyndJezWynd Frets: 6068
    I've got a Boss OD-3 in the classifieds at present. It does what you require. I A/B'd it recently with the Maxon OD-820 and it was identical save for the OD-3's enhanced bass response.
    http://www.thefretboard.co.uk/discussion/105879/fs-boss-pedals#latest
  • Ben8010Ben8010 Frets: 150
    edited July 2021
    Ben8010 said:
    @JezWynd I've had a listen to the OD-3 on a few videos before and it seems to be too generous on the bass for what I'm after. Of course demo videos don't always tell the full story
    It can be a little boomy if the bass is set too low with the Tone control, it's quite controllable though. Next to the SD-2 it's my favourite Boss drive pedal.
  • guitarfishbayguitarfishbay Frets: 7961
    OD3 was my first thought, not expensive to try and usually easy to find used
    edited July 2021
  • zepp76zepp76 Frets: 2534
    Exactly what I was going to say, save for a Sunset you'll never need another overdrive again.
    Tomorrow will be a good day.
  • bloodandtearsbloodandtears Frets: 1655
    Joyo  Vintage Overdrive?? cheap and cheerful..
    My trading feedback
  • exocetexocet Frets: 1958
    Timmy....you can tune the bottom end to suit.
  • PhiltrePhiltre Frets: 4173
    TC Electronic MojoMojo has masses of bottom end. At least Paul Gilbert thinks so (and so do I). Cheap, too.
  • equalsqlequalsql Frets: 6124
    Tele into a Blues Junior..
    Xotic BB Preamp or Emma Stinkbug
    They were born for that combination :)
  • CirrusCirrus Frets: 8491
    Fulldrive 2 is pretty good, to be fair.
    I really love my Pedalmods UK modded Boss SD-1. It's got the standard SD-1 mod 3-way clipping switch, a great midrange that's thicker than the standard SD-1 with a lower and wider midrange emphasis, a little more low end while still being on the bass-cutting side of things, and great top end that's articulate and clear but still smooth like I want an overdrive to be. It's one of those never-sell pedals for me.
    Funny thing is, I always liked it but I didn't realise how much more I prefer it to the standard SD-1 until I had one side by side with it.
  • DanDan Frets: 441
    Digitech Bad monkey (or hardwire cm-2 if you need true bypass)? Tubescreamer type but with seperate treble and bass.
  • timbuk02timbuk02 Frets: 271
    MI Effects Super Blues Pro gives you pretty much every TS-style sound you could want and more. The body adds more lows and the trim will help cut through. Has so many sounds in it, could easily have two. Unfort Andertons don't seem to stock MI any more but when these do come up on 3bay they go for under £70.
    https://youtu.be/pRM25lLFFKI
    and hear the body dial in this one at 1:30 - 2:00
    https://youtu.be/GN1JxAbgMoQ
  • NelsonPNelsonP Frets: 3395
    edited June 2017
    How about an Arion Metal Master. Contains JRC4558 opamps just like a tube screamer, but has high and low cuts on the pedal....
    ......only kidding, it isn't 1985!
  • 57Deluxe57Deluxe Frets: 7339
    edited June 2017
    The Blues Driver is a bit too mid-rich but one pedal that never fails to deliver glorious tones with any setup combination is my EHX East River Drive.
    Review:
    http://tonereport.com/reviews/electro-harmonix-east-river-overdrive
    <Vintage BOSS Upgrades>
  • Another shout for the Mojo Hand Rook. Or Bondi Del Mar.
