I finished mine in satin finish varnish. quite durable and not at all glossy. Lifted the grain a bit which was a shame, (agreed they needed sealing!).
Waxoil? I haven't time to rustproof my car as well, Ive more doors to hang. As regards the Danish oil I put it on an internal front entrance door (the one in the hall separating the porch from the external upvc door) With it being a well used door I found the edges got marked and a bit grubby with people either pushing it open or closing it and not using the door handle. I have read somewhere that using an oil on a veneered door can cause the veneer to lift because it soaks through the wood to the glue.
http://www.polyvine.com/index.php/en/varnishes/water-based-varnishes/wax-finish-varnish
I apply several coats when using Danish oil. On sideboard tops, coffee tables etc, where there is likely to be wear, I use a spray lacquer from Rustoleum and then wax to finish. I've just refinished a 1950s Danish coffee table which has oak veneer and the above worked fine.
there's loads of info out there... YouTube is decent for wood finishing stuff.
