New Boss - MS-3 - ignore me - new to me, but not to everybody else!
newi123newi123 Frets: 881
edited June 2017 in FX
Saw this today whilst browsing the guitarplayer website on a conference call...........
Looks interesting - combines multi fx and pedal switching - much like a modern mini G system I guess! From the connections can`t see you could use it in 4 cable method, unless you can use one of the loops to do that.
Look forward to reviews and seeing the price point.
https://www.boss.info/global/products/ms-3/
  • newi123newi123 Frets: 881
    People usually are! :-(
    How`ve I missed this up to now?
  • Ooh, option number 2 for mini-board:
    Get an MS-3 and have two ODs (Klone and Bluesdriver clone) and an El Capistan in the 3 loops.
  • professorbenprofessorben Frets: 5105
    Why a BD clone?
  • WazmeisterWazmeister Frets: 9607
    edited June 2017
    I must say, whilst I wait for my Helix, I fancy one of these for my analogue 'real' board...
    I do have 2 questions, which may not be answerable yet....
    1.) I wonder how this MS-3 would work primarily as a midi device; say compared to a Helix or Disaster Area ?
    2.) How will the effects compare to their Boss 'real' equivalent ?
  • TheBigDipperTheBigDipper Frets: 4813
    Re 1: It's not very clear how sophisticated the MIDI support is. I haven't yet found out (from the downloadable doc, I don't own one) how to programme MIDI, or how many commands on how many channels can be sent from one preset. Anyone worked that out?
    Why a BD clone?
    Because I already have one, the JRockett Blue Note. It's very good.
  • cbellangacbellanga Frets: 572
    It looks like you can control up to 4 devices. Looks like it sends CC and PC messages + midi clock
  • revsorgrevsorg Frets: 884
    This might be a stupid question but I was looking at the D&M Drive which can use TRS insert cables to integrate into a G2.  Could you use an MS-3 instead of a G2?
    Yes; works in exactly the same way. The D&M would take up two of the three loops on the MS-3 if I've understood it correctly
    You can stack the pedals, so you are not limited to 3 pedals, e.g. Klone & Bluesdriver in Loop 1, Rat & Tube Screamer in Loop 2, Delay & Reverb in Loop 3, or you can even use Loop 3 for 4CM.
    Did you get get one yet?
    No, haven't got one yet, not sure I could make use of one with this lot (minus comp, plus Rat clone & soon a JHS buffer).
    https://imgur.com/gallery/Q2bRK
    Might be better with an ES5.
