I have a basic pedal board and bought a cheap Caline power supply for it which seemed a good deal and the reviews were good.
I always had the feeling that I could feel electricity whilst using it but thought maybe I was just imagining it. But it's causing my amp to buzz and when I plugged it in the other day there was a spark from the plug.
I've tried in different sockets and the problem remains fiddled with the cables. Is the cause the power supply or is it something I am doing wrong?
I have it rigged as follows, tuner-compressor-OCD-BB Preamp-delay-looper
Also happens with different amps and different guitars.
In theory if your amp is properly earthed and you always connect the cables before switching on, it isn't actually dangerous because the system will be earthed via the amp, but this is still not good practice and you're right to be concerned.
Sounds like you had a bad power supply - if still under warranty then send it back.
My daughters boyfriend bought one and I was setting up a pedalboard for him with it.
The unit gave me an electric shock through the Metal tip of selector switch of my guitar and shocked me repeatedly . I removed the power supply and the electric shock stopped.
I will be looking into informing trading standards as these units are obviously dangerous.
It was this unit here..
http://i233.photobucket.com/albums/ee186/druckpig1/_DSC0505_zpsco1wxf91.jpg
I bought a new simple one this past weekend from the local guitar shop.
@Danny1969 has reported finding Chinese-made power supplies with poor isolation between the mains side and the low voltage side, it sounds like these may also be an example.
If the guitar and the pedalboard were connected to an earthed amp this still shouldn't happen though - this means something is amiss with the amp's earth, or the wall socket/wiring. Although there are some modern amps, eg Roland Cubes, which are intentionally not earthed (they're double-insulated) - was it something like that?
I now have a simple daisy chain set up for now with the same pedals and it's no longer happening.
The two occasions It zapped me I was in different buildings.
I am probably overlooking something that isn't earthed
How theyre allowed to sell such dangerous and poorly made products, I'll never know.
In any case replacing just the power supply box (the laptop charger type bit) with a better-quality 18V job should fix the problem without needing to replace the whole thing, if you don't want to.
I appreciate your advice re a better quality 18V power supply but I wouldn't know where to look to get one or how to to tell the difference between a good one or bad one and I would be concerned I will end up buying a 18V supply from eBay that is just as poorly made and dangerous
Could I just go to maplins to get an 18V supply.
I have had another look and the 5150 came with a EU type two pin mains lead and shaver type adapter which I have now changed and also there is Furman PQ-3 in the chain which has a ground lift switch so I suspect those may be the problem in conjunction with the dodgy Caline power supply.
Thanks
From Thomann? They really shouldn't be doing that for sales to the UK, but it seems common.
Thanks for the help on the power supply I will definitely look into getting one.
Cheers Ian
The problem you may be having finding an 18V supply is that the plug polarity is to be tip-negative, which is quite unusual outside musical-instrument applications.
If you could measure the actual voltage of the dangerous supply that may help, although it would be best to clip the probes on rather than touch it!
