Oddly I've had better luck with power valves than preamp. I often find 12AX7s going noisy in my amp. Trouble is, I use that as an excuse to change brand/model, and end up on tube changing spiral!
Hope it's not taken anything else out along with it - there was a flash and a horrible noise before I switched off, but no smoke or smell and the fuse is intact.
It's a bit unsettling, all the same! I did wonder if it's worth getting a bias probe and multimeter at some point and learning how to bias it myself, but if it's (hopefully) only every couple of years it's probably not worth it, plus it's probably best to have everything checked over after any electrical trauma!
contactemea@fender.com
Old-production valves like this can literally last decades, if they're run within the design spec. An old Sound City may well have old-production RFT valves, or similar - even if they were replaced in the early 90s, it's quite likely they will be the same, modern-production valves were just coming through around then but a lot of suppliers had old stock. 'Zaerex' was a very common brand for example - old-stock RFT EL34s from East Germany.
Modern valves tend to last nowhere near as long, they wear out quicker even if they don't fail.
I also have a DRRI, and we are doing another short tour later in the year and I'd like to be prepared.
So for a DR - 2x 6V6, GZ34 or solid-state rectifier, 12AX7, 12AT7. The DR doesn't have a separate HT fuse so just F1A fuses - you don't need many, one or two is actually enough.
If the fuse blows, replace the power valves and the rectifier, and try again. If it blows again, give up - it's not a valve problem.
Preamp valve failures don't blow fuses, they either stop working or go noisy or microphonic, and only one will be faulty - so you only need to swap one valve at a time for the spare to find it.
If all this sounds like too much trouble, take a spare amp or some other backup solution.
I know of a couple of 'Wimbledon' PA amps that sat in a cupboard in WMCs for over three decades and ran twice a week for bingo and then party bashes at Christmas time plus the odd wedding/21st.
GEC KT66, last forever.
My mate's TV shop have the contract with the local gen hospital to do the yearly service on the 50W Pamphonic amps that drove the headphone system. All the valves were replaced including 4X KT66 so I had a never ending supply of used but perfectly good valves! The fact that the amps ran 24/7 did not seem to faze them.
Dave.
