Need a Phaser and Chorus pedal. Suggestions please!
kswilson89kswilson89 Frets: 222
edited July 2017 in FX
The title pretty much explains it. Whats the best pedal in each category that you have used regardless of price?
Cheers!
«13
  • digitalkettledigitalkettle Frets: 3292
    I like Analogman chorus pedals.
    Currently got an EQD phaser which is good...not crazy but a lot more complex than a Phase 90 ;)
  • Winny_PoohWinny_Pooh Frets: 7788
    edited July 2017
    Phase 45 & Ce-2
    However, rock guys often prefer the 90 as its a stronger effect and there is TC chorus as an alternative for a more modern tone.
  • ICBMICBM Frets: 72515
    Phaser - Boss PH-1R.
    Chorus - Roland JC-120.
    OK... probably the Boss CH-1, although I'm not sure I've found the best one yet. (Currently have a CE-2.)
  • professorbenprofessorben Frets: 5105
    Eventide H9, a bit of a cop out I know, but it does sound the best for both of those sounds.
  • blobbblobb Frets: 2984
    For a good, cheap, outside bet, see if you can find an ARIA Chorus.
    I love the Phaser in my Ibanez multi, probably looking at a Maxon to get the same thing in pedal format.
    Feelin' Reelin' & Squeelin'
  • mike_lmike_l Frets: 5700
    MXR Microchorus. Dead simple to use.
    Digitech Multichorus, a bit more complex, but an awesome chorus.
    I haven't tried the bigger MXR chorus, but everyone I know whos' tried one (both of them) raved about it.
    MXR Phase 90. My own preference is the script* logo model, followed by the block logo one, or best of both worlds the EVH P90.
    *The reissue with the LED, not the original non-LED model.
  • noisepolluternoisepolluter Frets: 799
    edited July 2017
    I really like the MXR analog chorus (the small blue one) - the 2 band EQ is really useful for dialling in bright shimmery sounds or dark swampy ones.
    Phaser-wise I got an MXR phase 90 script reissue - love it.
  • dogloaddogload Frets: 1495
    Best phaser - Fender Classic re-issue
    Chorus - Ibanez BC-9 Bi-mode
  • capo4thcapo4th Frets: 4437
    Skreddy Little Miss Sunshine lovely chewy sound in a cool coloured surf green pedal and then add a Maxon CS9 Stereo Chorus pro. This pedal has a great depth control for how much sound you want on your Chorus effect.
  • JohnPerryJohnPerry Frets: 1622
    Best chorus: TC SCF
    Best phaser: Blackout Whetstone
  • MXR Phase 95 - gives you Phase 90, Phase 45 and both script and block modes. All in a mini pedal - staggering. If you can find one, Phase 99 is extraordinary but offers more than most people want.
  • BabonesBabones Frets: 1206
    Jam Pedals Ripple is a great phaser. Chorus, I like the CE-2. I'd fancy an original EHX Small Clone too though.
  • DominicDominic Frets: 16138
    mooer orange phaser
    cheap,simple sounds just like mxr
  • UnclePsychosisUnclePsychosis Frets: 12930
    Phaser: Boss Ph-2
    Chorus: Boss CE-2 with an honourable mention for the MXR Analogue Chorus (M234)
  • JezWyndJezWynd Frets: 6096
    edited July 2017
    Best I've used/use are the Maxon PH350 phaser and CS550 chorus. Both have an enormous range of sounds from a simple 3 knob config. Honourable mentions for Boss PH-1 phaser and DC-2 Chorus. The Maxons aren't to everyones taste, the chorus esp. has a hi-fi quality which is marmite for some, though I love it.
  • TeetonetalTeetonetal Frets: 7811
    Dod 201 is the best phasor out there imp, it's two stage, sound a little bit more subtle, which I like. Slow speeds for a bit of movement, and fast speeds it does that faux leslie thing really well.
    Chorus, I love the moog mini chorus, loads of sounds, but dialling it in can be a little awkward. Boss Waza chorus right up there too.
  • SassafrasSassafras Frets: 30301
    I've got one of those, it's quite noisy and there's a slight volume drop when you switch it on, but worse than that, it's a chorus pedal.
  • VJIvesVJIves Frets: 466
    If you like either to have the option of being a bit OTT, the Mr Black Doublechorus and the Alexander La Calavera are both very good options.
  • lasermonkeylasermonkey Frets: 1940
    Best chorus: Ibanez Bi-Mode Chorus.
     Best Phaser: Ibanez PT-9. It's very similar circuit-wise to the Boss PH-1r.
    My wife asked me to stop singing Wonderwall.
    I said maybe.....
  • MajorscaleMajorscale Frets: 1563
    MXR Phase 95 & Analogman Chorus
