Dulling a guitar that's been glossed
KylefKylef Frets: 1042
Looking at a guitar that was satin to begin with but has been polished up with a polishing compound. Is there something that would take it back down to a satin feel? My first thought was steel wool but I wouldn't want to leave swirl marks.
  • DominicDominic Frets: 16103
    soft cloth and Meths
    I'd use steel wool but you could always try a belt sander.
  • Philly_QPhilly_Q Frets: 22930
    I should wait for @WezV or someone to give the best advice, but I'd think 0000 steel wool is probably the way to go, making sure you don't get bits stuck in the pickups.
    Micromesh abrasive pads are also good and they come in loads of different grades, but maybe more suitable for little spot "repairs" than a whole guitar.
  • 57Deluxe57Deluxe Frets: 7339
    get it sandblasted like they use on Wheeler Dealers and Shed and Buried...
    <Vintage BOSS Upgrades>
  • scalino65scalino65 Frets: 261
    2500 grit or above wet sand?
  • JD50JD50 Frets: 659
    This... I found out by accident years ago when upon trying to clean sticker residue off a MIJ Jazzmaster I'd picked up off Loot, meths dulled the top coat really quick. I thought it actually looked better than the glossy poly.
  • LebarqueLebarque Frets: 3876
    I'm not an expert on this, but I guess it depends what the finish is - nitro/poly etc. In fact, I've got a nitro guitar that is very shiny, which I'd like to dull slightly. What's the best method? And while we're at it, how do you dull chrome, so it looks more like nickel?
  • Flanging_FredFlanging_Fred Frets: 3027
    Scotchbrite pads.
  • KylefKylef Frets: 1042
    It's a poly guitar that's in question. Tempted to go with wet sand 1200 up to 2500 or if anyone can recommend not to do that?
    Meths is what is used for stripping back Shellac/ French Polish
  • GagarynGagaryn Frets: 1553
    Wet sand with micro mesh cloth or pads - i love the stuff - great for polishing frets too - i've loads of the stuff from 1500 to 12000 grit
  • WezVWezV Frets: 16701
    Yeah, just wet sand with a high grit and stop when happy.  Micromesh really is the answer here.
    it will polish back up in the high wear areas though.  Not much can be done about that
  • bbill335bbill335 Frets: 1379
    I'd just use the scrubby side of a sponge
