so my amp is making an awful whine..... it's been like this since I bought a couple months ago but only just got round to playing the pre amp valve swap game until today.
put a new valve in V1 a Brand new premium selected and have been sawaping out the other 5 position one by one but no dice.
The whining noise is kind of tolerable in the clean setting and as I go through vintage gain / blues/ modern high gain it gets worse.
Makes no no difference whether reverb is on or off.
The whine is briefly magnified when I switch the amp off.
I am taking it in for service in September after my hols but if any of you good folk have any suggestion meanwhile?
Thanks
Does it still do it if the rectifier is set to Diode (solid state)?
Tap tested all the valves incl power/rectifier and no unexpected noise.
I wonder if it's something like a filtering failure in the LT power supply which is then being amplified through the LDR switches? Random guess!
Definitely one for the experienced tech if it's not a valve, anyway - these are not easy amps to troubleshoot, as you'll probably know if you've ever looked inside it. Unfortunately I don't have mine any more, or I could try testing some things.
Am taking it to John Kelly who has a good rep and decades of experience so he should be able to find the fault.
Thanks again!
