The speaker is a 30W 16-ohm, so you need an amp of no more than 20-25W, which has an output for 16 ohm, or at a push 8. You also may need a speaker extension cable if the stock one isn't long enough to reach a head - it may just be, depending on where on the head the speaker jack is… for example, it will probably reach with a Mesa Mini Rectifier, but not with an Orange Tiny Terror.
If you're only playing at home volume, it will be safe enough to use a higher-powered amp providing you don't turn it up too far.
If not you'll need a 1/4" extension cable - not difficult to buy, but make sure it is a proper one suitable for speaker current.
Ebay mark7777_1
