..... well I like to test you guys sometimes LOL. At tonight's rehearsal I had the most annoying thing happening (especially during my face melting guitar solos LOL). I randomly got volume drops or signal strength with my rig so much so that it took away my dirt/gain away somewhat. I have rebuilt my board a month ago and all has been working fine until now. Can it possibly be the EA patch cables I've made? I did test them with a meter etc. Could it be the guitar itself i.e. pickups/selector? Or could it be the power supply feeding the room? I say that because on some rare occasions I found I had volume drops using certain pedals in the same room however, I'm sure that would be a more frequent problem if it was.
Really not wanting to build the whole board again to check if it's possibly the board but gonna have to get to the bottom of it as I have a gig next week. Ironically I stripped down my board to make it simpler and now I get problems
Any pointers
How are you powering the pedals?
Is the guitar using active or passive pickups?
How much gain are you using?
Also where are your amps in relation to you/other amps/speakers? I'm thinking you're hearing the others above yourself and hearing a volume drop when there isn't one. This has happened to me more than once.
3PDT pedal switch
Pickup selector switch
Jack to plug contact
Patch cable (are the EAs solderless? If so they go to the top of the list)
Guitar cable
Guitar volume pot
etc
It's very unlikely to be a power issue - usually that will cause a complete drop-out, usually accompanied by a thump or loud noise.
sometimes they wiggle loose
on a big board they are a pig to trouble shoot but I would start with the guitar on and strummed open and give everything a wiggle
If it is a valve problem it will be a preamp valve - it probably won't be a power valve if the sound drops out to nearly nothing, unless it's a Peavey or Blackstar, and maybe some others - some of these run the power valve filaments in series. (Most amps have them in parallel.) A power valve fault would affect the volume and not the gain too.
I should have asked this earlier, but are the changes in volume sudden, or slow? Even fading over a second or two would make it much more likely to be a valve than a pedal.
What amp is it?
Cable/jack/switch faults don't do that, they cause sudden changes in volume.
was it a full moon last night ?
