Devin Townsend uses a Kemper for amp sounds and an Axe FX2 for effects, so the same would be possible with the Helix instead of the Fractal.
have seen a couple of posts of people doing it on the Helix facebook group. Looks like a super computer of digital goodness.
Also seen that Pete thorn has been taking a Helix floor & kemper toaster as his 'flying' Rig.
Not 4 cable method but so the Kemper goes in a loop of the Helix and is a patch in it's own right and the stereo out goes from the Helix to the speakers ????
I don't know much about the routing options in the kemper, or if you'd want to use the kempers Cabs or Helix's but for what you're describing ... I would guess you could use fx send 1 from helix into the front of the Kemper, then if the kemper has a non powered 1/4 out it could go into the return 1 in helix. Basically using the kemper in the same way as a full amp model in helix. Then split your signal (use stereo fx) after the kemper block, and use the L&R outs on helix.
