SOLD: Crate Blue Voodoo BV-60 head - £235 ono
Up for sale is this Crate Blue Voodoo 60 tube amplifier. It has a few scuffs in the Tolex covering but is in overall good condition and it sounds great. Due to the size and weight of the amp I would prefer local collection in London, however I could also deliver it personally within the London area.
According to the serial number (BV6WH60050), this amp was made in 1995. The stock tubes were replaced with two Groove Tubes GT-6L6B tubes a few years ago. In their stock condition these amps had a pair of orange bulbs behind the tubes to give off an orange glow. If you're keen on having the orange glow, the lightbulbs behind the tubes would need to be replaced, however the tubes themselves are healthy.
Asking £235 ono. I would also consider trading for a small tube combo like a Vox AC4C1.
Specifications:
Tube Types
Preamp: 12AX7A (3)
Power Amp: 12AX7A (1), Groove Tubes GT-6L6B (2)
Output Power Rating
BV-60H 50 watts RMS @ 5% THD 8 or 16 ohm load, 120 VAC
Gain
Channel 1 66dB, tones at “10” @ 1kHz
Channel 2 101dB, tones @ “10” @ 1kHz
Tone Control Range
Channel 1
Low 16dB @ 100Hz
Mid 20dB @ 300Hz
High 10dB @ 10kHz
Channel 2
Low 15dB @ 100Hz
Mid 13dB @ 500Hz
High 10dB @ 10kHz
Presence 5dB @ 10kHz
New Year bump
