Anyone got a spare small off cut of Paduak?
I was a bit of a twat about a year ago and accidentally sheared a screw off in my Paduak Chapman stick. I figure that it's about time that I jumped in and sorted it, Probably have to drill it out and put a plug in. I'd prefer it to be the same wood but I don't have any. I don't suppose that anyone has a small bit lying around that they don't want. I really do mean small, something I can get in the lathe and turn to about 8mm diameter.
  • RolandRoland Frets: 8749
    Is the screw large enough to drill into it and use a screw remover?
    http://www.screwfix.com/p/screw-extractor-5-piece-set/18643?
    Alternatively, collect the wood dust from drilling, fill the hole with something else, and use the dust mixed with glue for the last 2mm.
  • SporkySporky Frets: 28649
    I might have some in a pack of pen blanks I bought years ago. I'll have a look.
  • axisusaxisus Frets: 28341
    To be honest I'm pretty sure it's totally out of view, but as it is an expensive, quality instrument I'd rather do what I consider to be a good job.
  • leelee Frets: 12
    Yes I have load of off cuts you can have.
    Are you on PayPal, I could bung you something to post a bit over.
  • leelee Frets: 12
    Yes. Just tell me what size you want and I will hunt a bit out for you. If you send me a pm with your address I will get it sorted.
  • KalimnaKalimna Frets: 1542
    Im sure you know this already, but be aware that freshly cut padauk is often a considerably different shade than that which has been finished and exposed to UV for a while. So the colour match may not be great.
    Adam
    Adam
    Yes, I figured that would be the case, but as I mentioned, I'm pretty sure that it won't actually show.
    I was wrong about the pen blanks - no paduak to be seen - sorry!
    edited August 2017
    No worries, Lee sorted me a bit. All good to go now.
