Is there an Android app to measure distance walked?
RockerRocker Frets: 5006
I would like some way of finding out how far I walk when, say, I am in Dublin or Cork. One that uses GPS on my Android phone might be perfect. Thanks.
Nil Satis Nisi Optimum
  • I use Runkeeper.  Tell it you're walking, enable GPS and you're away.
    PSN id : snakey33stoo
  • fretmeisterfretmeister Frets: 24755
    I use Runkeeper on iOS but i believe there is an android verision
    Works well. Just set your activity to WALK and off you go.
  • monquixotemonquixote Frets: 17824
    Another recommendation for Runkeeper.
  • Strava does walks / hikes too. Use it all the time
  • mudslide73mudslide73 Frets: 3107
    Endomondo has a walking mode. I use it for cycling but it'll measure and map anything.
  • Also, if you link your strava account to relive you get funky things this after you go for a walk...
    https://www.relive.cc/view/1134858927
    That was mine yesterday :)
  • Google Fit.   Integrates with plenty of other apps too.
  • BigBearKrisBigBearKris Frets: 1766
    Samsungs usually come armed with S health app which will count steps, measure distance etc.
    For GPS + map tracking, as above: runkeeper, Strava, Endomondo.
  • It's worth saying that a phone battery doesn't last long on full gps tracking mode. If you're doing more than a couple of hours it's worth getting a basic GPS watch. Battery life on those can go past 15 hours on gps mode. I actually use a Garmin Forerunner 35 for walks and runs and a Garmin Edge 810 bike computer for rides. They both pair with my phone, upload immediately I finish an activity and are brilliant. Also means I have phone battery in an emergency.
  • crunchmancrunchman Frets: 11495
    I've used Endomondo in the past.  There was another one that I think was called Sports Tracker that I used as well.
  • Hertz32Hertz32 Frets: 2248
    GPS essentials is my favourite. It'll show your velocity and altitude and all sorts
    'Awibble'
  • ESBlondeESBlonde Frets: 3597
    Another Endomondo user here. Lists dozens of activities and gives possible outputs for each, simple things like walking, running, cycling, canoeing, rollerskating etc. with different modes in many of them.
  • VaiaiVaiai Frets: 530
    Runkeeper and Strava but also Map My Ride/Map My Run. If you are a bit more serious then getting a GPS device means it can track your walk then upload to your phone/PC as the phones don't always have charge for a full days walking and using GPS. Also the phone can lose signal whereas the dedicated GPs devices are more suited to the job.
  • jonevejoneve Frets: 1483
    This.
