Since 2008, The Hotcake has included a jumper switch system. This system allows the user to change the setting to The Hotcake Bluesberry specification. Using the same jumper switch system you have a Bass Accentuation facility. We advise the user that the settings should not be altered on a regular basis – the jumper switch system is in place to allow the user to fix a setting and is not intended as a constant switching option.
