Ok... lead tone pedal help...
wingo84wingo84 Frets: 42
Use an elite Tele into a Victory V40 with a few pedals in between
polytune
Xotic Wah
Philosophers Tone
SL DRIVE**
AC Booster
RC Booster
EP Booster
DD500
neunaber slate
**the Sl Drive doesn’t do it for me. I want something that I can dial in a smooth lead tone.
Thoughts are on...
Xotic Soul Driven
Keeley D&M
J Rockett Dude
what would you guys say? Just gathering thoughts!
  • JDEJDE Frets: 1092
    Is your amp set clean or dirty? Will you be stacking it with the AC at all?
  • Clean amp setup... Muffcloud stacked with an overdrive/distortion of your choice both the sustain and volume whacked up on muffcloud
  • BeexterBeexter Frets: 616
    Buffalo Fx Evolution into a clean amp.
  • tone1tone1 Frets: 5186
    Muffroom Cloud into a treble booster is my current favourite
  • photekphotek Frets: 1468
    edited August 2017
    The best lead tone when I had my V40 was with a Lovepedal Hi Volt, there was one for sale in the classifieds recently. Smooth singing lead tone with plenty of eq so you can get it to sit right in the mix.
    If you can't find a Hi Volt, Suhr Riot worked well as did the Bearfoot Dyna Red Distortion.
  • MrMusicMrMusic Frets: 44
    Analogman King of Tone or The cheaper Prince of Tone
  • TimmyOTimmyO Frets: 7560
    edited August 2017
    2 pedals I've used in the past for a good "insta-lead" sound :-) -1
    Zendrive
    Xotic BB Preamp (even better if you can get the 'MB Custom Shop' version where you can tune the mid boost to taste)
    Both are great - as is the (discontiued but you can find them used sometimes) Zoom Hyper Lead which has a really powerful EQ
    Red ones are better.
  • do you mean just an eq/gain/tone thing or a "cut through the mix in a live situation" thing?
    https://www.gbmusic.co.uk/
    PA Hire and Event Management
  • because between the ac,rc, ep and sl you can pretty much get any lead tone out there, minus specific fuzzy stuff haha..
  • koss59koss59 Frets: 855
    The Dude is incredible if you want thick, sustaining solo tones.
    Facebook.com/nashvillesounduk/
    Have you considered an EQ pedal? My cheap Joyo 6 band EQ can turn the harshest of screechy crunch tones into a smooth as a baby's bottom lead tone.
    If you use it in front of the amp you can even dial in a boost a the same time as shaping the tone.
  • wingo84wingo84 Frets: 42
    Its a single channel clean amp, great pedal platform
    and I could stack with the AC... the AC is great... but just want something with more Drive really.
    Something that will drive more and get a smoother lead tone. I’d be pushing with my RC. The SL works well, just wanted a slightly less plexi tone... it’s really hard to describe
