If you can't find a Hi Volt, Suhr Riot worked well as did the Bearfoot Dyna Red Distortion.
Zendrive
Xotic BB Preamp (even better if you can get the 'MB Custom Shop' version where you can tune the mid boost to taste)
Both are great - as is the (discontiued but you can find them used sometimes) Zoom Hyper Lead which has a really powerful EQ
PA Hire and Event Management
If you use it in front of the amp you can even dial in a boost a the same time as shaping the tone.
Its a single channel clean amp, great pedal platform
and I could stack with the AC... the AC is great... but just want something with more Drive really.
ChrisCox1994 said: Something that will drive more and get a smoother lead tone. I’d be pushing with my RC. The SL works well, just wanted a slightly less plexi tone... it’s really hard to describe
