Best way to remove scratches on guitar?
Been a bit clumsy and managed to scratch the laqcuer on my Gibson Midtown.
Any recommendations on how best to restore it? Gibson pump polish has improved them, but if there's a better way...?
Never ever bloody anything, ever!
  • DougDoug Frets: 172
    If it's just a fine scratch in the laqcuer then some compound(Farecla G3) followed by  Autoglym resin polish should sort it, if it's a deep scratch then wait for a response from the paint guys @lamf68 @Billkat etc.
  • CorvusCorvus Frets: 2933
    As Doug says, if it's just a light flesh wound, pic would help. If it's deep & nasty options would be like drop fill with clear lacquer, or tinted lacquer, flat & polish. Sometimes heavily thinned lacquer run in a small scratch with a fine brush will melt in quite nicely. Won't be invisible without flatting out; sandpapers, blocks, compounds - time & money. It's easy to make things worse if you're not familiar with filling & flatting back & polish up.
    Sometimes these things are best left. To me an honest scar is usually better than a drop-filled one, bad-sanded one etc.
  • Sometimes these things are best lef. To me an honest scar is usually better than a drop-filled one, bad-sanded one etc.
    What he said, just leave it - trying to hide things especailly on a highly polished gibson finish sometimes spirals out of control if you dont know what youre doing and before you know it youre wet sanding the entire body and wishing youd just left it. If its just some light scratches you could try with a very very gentle cutting compound, but again its easy to make things worse
  • GassageGassage Frets: 30945
    Most luthiers are far more skilled at how to put fake scratches on than take real ones off, these days.
    2reaction image LOL 0reaction image Wow! 2reaction image Wisdom
  • DefaultMDefaultM Frets: 7372
    Hold the body with both hands, find where the scratch is, and then knock that part of the body on a table.
    If done right you should no longer be able to see the scratch.
  • The scratches are only on the lacquer, not through to the paint. Agree with you, Gassage lol
  • New guitar.
  • richardhomerrichardhomer Frets: 24848
    edited September 2017
    Put a nice 1970s Musicians Union 'Keep Music Live' sticker over it.
  • Keep being clumsy and save yourself a lot of money getting it "relic'd" later!! ;)
  • Brasso.
    Apparently works well at getting scratches out of plastics.
    WD40
    Works at getting scratches out of laminate flooring( although you will slip on it and break your neck after).
    One or the other or neither.
  • RoxRox Frets: 2147
    I was going to say "belt-sander" or battery acid.  But I'm no expert.
  • As I've said before - used lightly, with a soft cloth - T Cut is perfectly fine....
    I've used it on a vintage Gibson with no ill-effects.
  • guitars4youguitars4you Frets: 14345
    for superficial surface grazes there are various guitar polishs to choose from but I get good results with Meguiars X20 car polish - As I said more for superficial top surface light grazes
  • SassafrasSassafras Frets: 30301
    Get a Telecaster.
    The cack-handed clumsy oaf's guitar.
    1reaction image LOL 1reaction image Wow! 3reaction image Wisdom
  • Sassafras said:
    Get a Telecaster.
    The cack guitar.
    Ftfy
    Sassafras said:
    Get a Telecaster.
    The cack guitar.
    Ftfy
    I can't help getting the impression you don't like Country & Western.
  • proggyproggy Frets: 5835
    I used to use T Cut for my scuffs and scratches, these days I just leave them, they add character and value!
  • WezVWezV Frets: 16757
    I agree.  I have used it on quite a few  Gibsons.
    funniest one was a mates 90's white studio.  It got stained pink when he played a gig dressed as a lobster.  He did nothing about it for 2 years.  Normal cleaners wouldn't shift it by the time he asked if I could take a look.
    you do have to do the whole thing though, even if it's only lightly
  • Sassafras said:
    Sassafras said:
    Get a Telecaster.
    The cack guitar.
    Ftfy
    I like both types of music.
