SOLD - Gotoh SG381 HAP machine heads with oval buttons
Barely used and unmarked. 16:1 ratio I believe. The only problem is that I have lost one of the hex threaded inserts, but they are the standard size and usually a straight swap (Squier, Fender). These have the height adjustable pole pieces for staggering. I won't be able to post these until the 5th October, so if you're in a rush you'll need to look elsewhere... Cheers
:-)25 quid posted PPG.
www.victorludorum.org/P1100352.JPGwww.victorludorum.org/P1100353.JPG
Bandcamp
