@Neil is the resident forum watch expert.
I use a local chap and he's not taking on any more work as he is retired.
Brendan Hoey - serviced and polished my wife '66 rolex. Very helpful and prompt.
webwatchmaker.com
If equivalent parts are used in your Omega watches @lewism, then you cannot sell your Omega as an Omega. Watches are not like guitars, the vast majority of buyers have no way of determining the Omeganess of an Omega. Same story with Rolex or indeed any watch.
Nil Satis Nisi Optimum
Your point about obsolete mechanisms is a valid one, I admit to not thinking along that line when formulating my comment.
https://www.genesiswatchmaking.co.uk/index.html
I would send it in to the manufacturer. As has been stated by Rocker, you will get a full job done and it will be guaranteed, worry free. When you look at the skill of the engineers who work on your watch, even though it seems a lot of money, it is good value. After all, a solicitor or accountant will charge you £200 an hour, so 3-400 quid for a service and parts is not too bad.
Its also things like replacement of seals - if the manufacturer does it, then the water resistance or proof is assured (as it was new).
The only alternative is if you can find a local watchmaker, and these days they are becoming increasingly rare. I used one years ago to fix a problem on a Breitling. He charged me £28! However, its a diving watch with a helium escape valve, and none of that will be active now. Not that I dive, so don't matter. Breitling would have charged about 300 but it would have been serviced and regassed, and the seals replaced, so I could safely dive to 1000M again. Seeing as I don't even swim in it, not a problem!
Contrary to popular belief most vintage movements don't usually need replacement parts. Let's face it the gears etc are under such little torque they will last forever.
The main part that may need replacing is the mainspring and Omega will have theirs made by an outside contractor anyway .
No one can tell a pattern part from an OEM Omega part anyway but aside from this there are still plenty of old Omega parts floating around anyway and watchmakers worth their salt will have a stash of this type of stuff.
I've got lots of 60's Omegas that still have all original parts.
