use your ears, they're fundamental in the hobby of guitar
It will work just as well (or not, depending on who you believe) with active controls.
So from one Sound City source:
Each tone control in the Mark 4 "active" preamp, which was first available with the introduction of the 50 Plus, 120, and 200 Plus amplifiers in about 1973, acts as a sort of gain control for that tone control's specific range: i.e., Bass, Middle, Treble, and Presence. If all "active" tone controls are set to zero (0), no sound will be available from the amp even if the Volume control is set to 10.
According to the Mark 4 preamp's designer, the circuitry of the "active" preamp represents a "ladder circuit" where the signal from the Volume controls is "fed" to each tone control (i.e., each rung) in the ladder, and each tone control is essentially a gain control driven by its own ECC83 tube. Although scorned by some, this feature of the "active" preamp explains why the Sound City Mark 4 amps are very loud amps indeed.
Appreciate that doesn't help you much, but at least you know how it works!
