Push to break switches
ChaosJunky135ChaosJunky135 Frets: 11
edited September 2017 in Making & Modding
Hi all
The band im in at the moment requires a killswitch for a few of the songs, however i dont want to cut a hole in my baby below to fit one. Does anyone know where i can get a push to break foot switch ( cant find one anywhere ) as i was going to make killswitch pedal instead.
Thanks in advance
https://www.flickr.com/photos/151507629@N04/36595174383/in/dateposted-public/
  • Danny1969Danny1969 Frets: 10455
    Use a push to make so when engaged it shorts hot to ground, simple as that
  • ICBMICBM Frets: 72603
    Also the correct way of doing it :).
    A push to break will cause quite a lot of hum instead of silence when engaged.
  • Cheers Will have to have a look and see what i can come up with
  • m_cm_c Frets: 1247
    To help your searching, push to make is more commonly know as NO (Normally Open), and push to break NC (Normally Closed).
    You can get industrial pedals for not that much money, but longevity of the switches may be a problem, as only switching relatively small currents can cause the contacts to oxidise (switch/relay contacts rely on arcing to clean the contacts).
    RS have a reasonable selection - http://uk.rs-online.com/web/c/switches/foot-switches-accessories/foot-switches/?searchTerm=normally open foot switch&sort-by=P_breakPrice1&sort-order=asc
  • SporkySporky Frets: 28666
    Pretty sure you can do this with a Boss FS5U and a TRS to two TS cable.
  • You could get one of these
    www.brightonion.co.uk/products/Mono-Momentary-Kill-Switch.html
    Thanks a lot dude, how did i not find this before haha
