I use teflon jacket 7/0.2, colour coded so I can tell what's what.
The good stuff cuts cleanly and doesn't fray too much as long as you use sharp snips. At most, the ends can look a little fluffy. It's quick to use and looks nice
Then the other type sold by some uk suppliers. It starts to unravel as soon as you cut it. Rather than fluff you are left with long strands sticking out and a total mess. It's harder to work with because you can't see wire strands and need to spend time tidying up afterwards
Instagram
I stock both, and one is basically a woven covering that acts like normal plastic coverings, and the other is the good vintage stuff. But there's a significant cost difference between the two.
http://www.thefretboard.co.uk/discussion/60396/
Find an old Scart cable and cut it open. There must be literally millions of them out there - if you can't find one in your own house, most charity shops have any number of them for 50p each. There's enough wire in just one to last you for a couple of years of DIY electronics work at least.
Sounds like the beginning of a ritual to appease the AV demons. I approve.
To be fair, SCART is only about the fifth worst AV connector I can think of quickly...
It has no impact on tone as some might have you believe, it just looks cool and is easy to work with.
I've also started using some solid core cloth wire from HotRox which is great for connecting toggle switches to pots etc...
It's very easy to use but some charge a mini fortune for it - I will be looking out for old scart leads from now on! Great shout.
https://sixstringsupplies.co.uk/
Our YouTube Channel for handy "How-To" Wiring Tutorials
It's nice stuff, imported loads for my harnesses a while back.
