Floyd Rose - does it need a locking nut?
axisusaxisus Frets: 28347
Can you get away with a decent nut and locking tuners or does it require a locking nut?
I'm thinking of swapping neck on my FR guitar, but I don't really want to install a locking nut unless absolutely necessary
  • ICBMICBM Frets: 72702
    If you want the absolutely rock-solid unshakeable tuning stability that a Floyd is famous for then you do need the locking nut.
    If you just want pretty good stability, a bit better than a standard Strat-type trem, then it will work fine with locking tuners if you pay attention to cutting the nut well and minimising friction at the string tree - which in my opinion you still need even with staggered posts, I find the break angle is always too shallow on the first three strings, so I prefer to fit the tree and use the lowest post for the G string.
  • axisusaxisus Frets: 28347
    interesting ...
  • CatthanCatthan Frets: 366
    There was an episode of Tim - Pete show where @Petethorn was showing his 3TSB Suhr strat to which he had swapped the trem to a floyd-type (iirc one like the very first ones w.o. fine-tuners) and stated that with locking tuners it was good enough.
    I suppose you need a well-built gtr in which the hardware works well to start with (like a Suhr) but it can be done apparently..
  • mrkbmrkb Frets: 6931
    Hmm, my Floyd Rose (with locking nut) goes so slack that the strings are floppy, so they wouldn't stay in a standard nut slots while its that slack. You would need a string retaining bar or similar behind the nut to keep the strings in the slots.
    Karma......
    Ebay mark7777_1
    They don't go quite as slack without the locking nut because the length of string beyond the nut takes up some of the movement, but if it was an issue I would put a block on the back wall of the trem cavity to stop the bridge going that far forward, rather than add a bar which will definitely cause friction and tuning problems.
  • What if you want the bridge to go that far forward? When I use a Floyd I push it down very hard for mximum divebomb cool
  • crunchmancrunchman Frets: 11472
    Rather than swap the neck I'd swap the guitar.  Having said that I wouldn't buy a guitar with a Floyd in the first place.
    I'd rather have a Bigsby.  Who is that that gets wound up when you mention Bigsbys?
    In that case you do need a locking nut. They are definitely a solution to a problem, which works.
    It's always amusing to point out that a Bigsby also has a larger bend range than a Floyd too.
    It's just that most of it is upwards :). Until the strings break, if you like...
    Yes, but here's the thing - It's a self made guitar but I didn't make the neck. I want to make my own neck for it.
  • AlnicoAlnico Frets: 4616
    @professorben
    @professorben
    @Bridgehouse ;
  • prowlaprowla Frets: 4970
    Well, the guitar will be playable with a Floyd and a standard nut, so long as you don't dive-bomb.
    But it's kind of missing the point.
  • You *might* get away with it if you have locking tuners with very little wind, but otherwise there's no way it will stay in tune unless you artificially limit the range you use the floyd to that of a typical strat bridge.
    Accidentally go too far on a dive? All your strings are out of tune, or worse, off the nut.
  • I've just bought a non-fine tuner Floyd Rose and a set of staggered Hipshot locking tuners for a Strat build. Kind of like the Charvel Guthrie model. Tom Anderson use the same bridge ('recessed vintage locking') on a lot of guitars too. As there are no fine tuners you can't use a locking nut!
  • DLMDLM Frets: 2513
    @professorben
    @Bridgehouse ;
    @Bucket
    @Professorben is Teles!
     No no Bigsbys too.
    Now bigsby on a Tele!!!!  :s
    Shh! No one tell this guy!
    https://www.metal-archives.com/images/8/0/1/1/8011_artist.jpg
    Specially for @professorben ;
  • GoldenEraGuitarsGoldenEraGuitars Frets: 8825
    I had an Ibanez RG870QMZ a few years back. I rarely used the locking nut. It stayed in tune beautifully. I usually spent a long time setting the guitar up and stretching the strings. It allowed me to tune  the guitar as normal without using the fine tuners
