Random Sperzel Fail
Sat down with my gently used (though highly modded) Gretsch Corvette this afternoon.  Unusually, it was out of tune.  Gently turned the low E tuner, nothing happens.
It it looks like the Sperzel has died.  Turning does nothing.  Looking at the back (lower right hand side in photos), it looks like something has worked loose on the opposite side of the tuner to the peg.
Photos:  https://imgur.com/a/nbFcu
is this repairable?  It’s had no abuse, had an easy life, suffered no dings or bashed.   Any thoughts?
if it can’t be fixed, where can I get a spare...?
Thanks for any advice offered,
Marlin
  • WezVWezV Frets: 16811
    edited September 2017
    Push it back in and tighten the screw on the button.
    this is the part you can see sticking out
    you can fully disassemble sperzels really easily.  change them for left/right handed use or mix different colours - the downside is they occasionally work themselves apart on there own, but i doubt there is anything actually wrong.
    https://www.guitarpickups.xyz/blogs/how-tos/71471107-how-do-i-turn-my-6-in-line-or-3x3-sperzel-tuners-into-a-4x2-set
  • ICBMICBM Frets: 72731
    If it is actually broken, I think I have a few spare single ones.
    Yeah, I have quite a few spare parts for these too.
    i had a few with broken locator pins... the main weakness in the design
    still love sperzels though
  • TheMarlinTheMarlin Frets: 8037
    I tightened it up, popped the string back on, but a half turn later it’s apart again.
    Something must have failed in there...
    i’ll pull It apart in the good light tomorrow, and see if I can see anything obvious...
  • SimpleSimonSimpleSimon Frets: 1025
    Hope you get this sorted, ive never had any issues with Sperzels personally. More importantly we all want ot see pics of that white corvette - only ever seen them in cherry before!
  • DefaultMDefaultM Frets: 7385
    Has the pin fallen out?
