Pickup Wire Too Short
paulphoenixpaulphoenix Frets: 141
edited October 2017 in Making & Modding
So i'm in the middle of replacing both volume pots on my epi les paul and tidying up my 50s wiring, but one of the pickup wires is a little short - it's in the cavity by about an inch, but my life would be easier if i had a little slack to play with.
Whats the best way to extend the wire? any tips/tricks/pointers?
It's a seymour duncan humbucker with braided shield (2 core/conductor) wire if that helps (or hinders)?
  • sweepysweepy Frets: 4190
    Solder and sheath extension wires to the original, it'll be fine
  • ICBMICBM Frets: 72514
    If you haven't done this already, check it's not got caught the wrong way round one of the pickup legs in the pickup cavity. That shortens the cable somewhat :).
    If it's not that, what sweepy said - add a couple of extension wires and heatshrink over. The extension doesn't need to be shielded over a short distance like that.
