Wishbone ash used them on "Just testing" I think
and U2 on with or without you live
http://jasobrecht.com/u2s-edge-talks-guitars-gear-techniques/
I eventually bought a Fernandes sustainer guitar, much easier to use, which I think is similar to this:
https://en.wikipedia.org/wiki/Infinite_Guitar
The Fernandes/Sustainiac systems are much easier to use, although obviously they do need to have a dedicated guitar for them.
Takes a bit of practice to get working right, and even more if you want to switch strings during play. I only ever use with the neck pickup - bridge sounds too harsh. It also drives the string very hard, so watch the volume. On the plus side of that, because it drives the string hard, you can work with harmonics on the strings that normally wouldn't be audible - some great atonal sounds, if that's your thing.
I made mine grippier on the sides as it’s easy to drop...and thus break.
If you put it away ‘wrong’ there’ll be no battery left when you come back to it.
Great fun...great recording tool too.
that's what she said / giggity ?
Effects for Me & my Monkey YouTube channel Facebook Fretboard's "resident pedal supremo" - mgaw
The easier place to use it is on intros, where you can get it ready, and then just put it down quickly before going into the song.
Now that you've mentioned it I might unearth mine and use it tonight on one of our intros.
just found a 2014 Wishbone ash album that uses them quite a bit: Blue Horizon
I'm wondering about using one on a lap steel now.....
Best way to use it live is to make sure you mute all the strings with your left hand when you put the bow on the strings. Set guitar to neck pickup and slowly slide the bow towards the pickup until you swell up to the right volume. If you just plonk the bow right near the pickup straight away you'll deafen everyone and piss off your band mates.
As a physicist/engineer type, I can't work out how the harmonic mode works. In the normal mode, electromagnetic energy is transferred to the string and it just vibrates at the fundamental frequency, which is detemined by string mass per unit length (gauge), tension, and string length (i.e. where it's fretted). So how does it excite the 2nd harmonic?
