Sorry .
If it came off in the case with no impact then the piece of wood used for the neck must have been weak, even for it to happen with 12s. To fix this properly you will need to splint it - which means inlaying two pieces of new wood (some repairers use maple as it's much stronger than mahogany) through the broken area either side of the truss rod. Obviously that means it will need a refinish over that area as well.
I would also pick Feline Guitars to do it.
thanks for the repairer suggestion
definitely splints in that case. I don't jump to them on first break unless it's shorter grain. Although a mystery case break without a knock will more than likely be a short grain break. If it had a long grain break in the case you can be fairly certain it had a knock you don't know about
Instagram
