My small den is bursting at the seams, and I need to create some space and sell some gear - just too many guitars, amps, pedals, MFX for my needs and in such a small space. I have no 'dogs' and I like everything I have, so I know I'll miss whatever I sell, but I've got to let go of some stuff.
Definite guitars:
Yamaha 611VFM with brand new tweed hard case - only because my PRS Cu24 covers h/b & single-coil tones
Washburn EA30 electro-acoustic with padded gig bag - lovely guitar, but I just don't use it.
Maybes:
Epi Sheraton II (Korean, Samick, 1989) plus hard case - simply because I just don't play it as often as my other guitars
USA Deluxe 50th Anniversary 2004 Strat - pure mint & unused, bought as a modest investment, and kept behind our sofa as no room in the den.
Definite pedals:
Marshall Blues Breaker BB2
Marshall Jack Hammer JH1
Vox V847 wah, chrome body (battery version, but I have a nice little 'snap-on' adapter so it be also be mains powered
I already have the Guvn'r2 on my pedal board, and I rarely use wah (I have wah on my TL mfx's anyway)
So - amps. And this is a biggie because of size, weight & bulk. Before making a decision here I need to try out a Boss Katana 100w 1x12 with floor controller. If this is as good as everyone is saying it is, then I'd sell my Marshall JCM2000 DSL401 and possibly Vox Valvetronix AD120VTX plus cover, and VC12 floor controller (+ gig bag). Parting with the Valvetronix/VC12 would be a massive wrench, because it's such a great amp, but I no longer need such a big, heavy, loud 2x12 amp for gigging, and it's the biggest amp I have so would release some much needed space.
And MFX - this is another difficult one as I currently use my Vox TLSE for rehearsals and gigging. But I also have a TLLE which is smaller and lighter and if I can run a volume pedal through the insert loop for extra gigging control, then I might part with the TLSE. If I sell the AD120VTX/VC12 then I might keep the TLSE - it's the same size as the VC12 and could occupy it's space under the raised plinths I have my amps on.
I know this post is a bit of a flow of consciousness, but I thought it would help me if I laid out my thoughts and rationale. It's just that like so many folk here, I've made mistakes selling gear that I should have kept, and hence why I'm a bit 'clingy'.
Ive had a recent purge to clear space and to afford to revamp my pedal board. It's been quite cathartic - and now that the guitars are gone, I don't actually miss them. I have happy memories of them but don't need them in my life right now.
fwiw, I've dropped from more than 25 at the beginning of the year down to 13. I may go lower still...
Maybe I need to buy TWO more...?
Yamaha 611 - I moved my 311 on about 18 months ago and haven't missed it one bit. Although it was a perfectly decent instrument IMHO it lacked any kind of personality or 'mojo'.
Marshall BB2 - good call. One of most insipid drives I've owned. Although, to be fair, the clean boost wasn't at all bad. These days I very rarely use a drive pedal; I use the guitar's volume knob to control things.
I would work out what my essential/favourite tones are and the minimum equipment to reasonably achieve them
And then dump the rest
1980 Tokai LS-80
Don't do it - or not unless you can find a 60W one. That's half the size but otherwise basically just as good.
Sell the DSL first anyway. It's an OK amp, but not a great one.
Fender collectors of the future (if they still exist then) will more than likely be buying the 04 Masterbuilt 50th '54s, which again are at the moment worth no more than they cost new with the possible exception of a John English.
My guitars occupy our boxroom along with all the amps and recording gear. It's a tight squeeze but I haven't reached the stage where I would get rid of any of it. That's not to say I have anything special to raise a good sum of cash.
I wondered what are your thoughts on your 611? I don't see too much similarity with the Yamaha and your PRS but maybe you're not too fussed about the P90 grit.
