£1.50 for the smaller one and £2.50 each for the larger sizes.
I recently used it to make a 18v power lead for some EMG pickups and it worked great, so that was the £1.50 pack.
It's about 6mm (ish......from memory) until you heat it and it fitted the power wires from the battery clip perfectly.
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
As ever CPC is the cheapest place with the biggest selection
To state the obvious, watch the finish of your guitar if you're in there with a hot air gun. I've got a gas soldering iron with a tube shaped hot air nozzle so you can concentrate the heat to a small spot and not damage finish, other wires etc.
I also find that you can use the tip of an ordinary soldering iron - hold it very close, a mm, from the heat shrink without touching it. If you move it around, over and under the sleeve that usually works too.
Easy to control and as said, right there and hot already.
