In general the relationship between distorting effects and others is the most important. For a drastic example distortion before reverb means the reverb is added cleanly on top of the distortion. Distortion after reverb will distort the reverb and give a very different result
Fortunately, Strymon have you covered. Set the pedal to pre/post mode, put your dirt pedals in the loop (L Out to pedal input, last pedal output to R In) and you can select in each patch whether the effect comes before or after your distortion.
http://www.strymon.net/manuals/Mobius_UserManual_REVC.pdf
Page 22-23.
IMO most modulation effects sound better before distortion, but most sound good both ways. Except rotary speakers, which only sound good to me after distortion.
