Headstock's definitely split. Not the hardest repair, and probably doesn't even need repairing really. £200 is probably fair (ish), as the e series squiers are normally really nice playing guitars. Prices seem to be around £300-400 mark.
Try get it for £150, then pay £40 to a tech to glue the split.
If you are buying, haggle for a discount.
If you are selling, it is probably wisest to lower the price and let the buyer pay for a repair tech.
Cheers!
This will not occur when a split is in the wood. Considering that there is no evidence of impact around the headstock area, the issue could be shrinkage. The most likely cause is an over-tightened screw.
Precisely. A lot of work, for zero reward and likely to reduce the perceived value of the guitar. Hence, my suggestion to pass the problem on to the purchaser. If the purchaser fashions an ugly repair, that is their problem. They take the hit at resale.
