Harsh but fair.
The pivot/spring arrangement is just one of the "delights" of that vibrato system. Next, you have the moving bridge to contend with.
Conventional wisdom is to put as much tension as possible on the springs. I like to restrict the movement of the bridge by packing out the pivot cup "thimbles". String gauges of 011 and upwards aid tuning stability. With all of these things sorted, the system should reliably offer gently shimmering wobbles. Nothing more.
It stays in tune absolutely fine and I do like to make space invaders noises with the trem...
There are some good tutorials on YouTube which should help set up the trem.
On my '66, the "cigar tube" (the tailpiece) is really low, the strings barely fit between the tailpiece and the vibrato plate. It only goes down in pitch but I have very little problems keeping it in tune. I had an MIJ set up in a similar way and it worked alright but the vibrato action was not smooth or pleasant and the unit made a horrible creaking (it didn't come through the amp but you could feel it in your right hand).
People like Ty Segall and Charlie Moothart seem to get away with floating theirs really high and just shove the tailpiece around with their right hand.
i’ll try restricting the bridge posts too.
