Gents,
It's NGD for me - been lusting after a Custom Shop 56 Start with a roasted maple neck for some time and pulled the trigger on it today.
It has 'postmodern 50ies wiring to retain more treble' - whatever the F*ck that means?
At home, I'm loosing too much treble when I roll past 7 on the volume and I'm looking at putting a treble bleed (220k / 650pf from memory) on across the volume pot to retain some more treble, as I've done with Strat types before
Looking at the volume pot, there's the standard wire from the 5 way going into lug 1 and lug 2 goes to the jack, but also a wire coming from the 1st terminal on the 4 terminal side of the switch which is going direct to the wiper lug of the volume pot
What is this?
Any issues with me putting the above treble bleed across the 2 volume terminals?
To properly retain treble you need a treble *pass* circuit. There are a range of values which work depending on personal taste/cable length etc, but between 180pF and 1000pF for the cap and between 150K and 470K for the resistor are about the outer ends.
I’ve stalled the treble bleed (the 150k / 680pF is the Suhr treble bleed, which has always worked perfectly for me)
I’m currently at the vets (..no really) so will test when I get back and report back to base ..will take pics if I need to open it up again
Baz
http://www.stewmac.com/Pickups_and_Electronics/Components_and_Parts/Capacitors_and_Resistors/Golden_Age_Treble_Bleed_Circuit.html
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
A dramatic difference with the treble bleed in place - much more usable and some classic Strat tones in there, but probably a tad too bright now below 7 on the volume - a bigger cap might be in order?
Jonathan - any recommendation on capacitor brand?
Would the combination of 50ies wiring and the treble bleed be accentuating the treble bypass?
No, if anything it will reduce it since the tone control now follows it.
By the way, this is a treble *pass* network. Treble *bleed* is what the tone control does.
The rest is all about posing value and as it's hidden inside the guitar doesn't matter
ICBM being right again
Sorry - I know that 99% of the internet calls it a treble 'bleed', but it does annoy me!
@icbm - indeed - ''tis certainly passing less treble to ground
Sounding pretty good now, so thanks for all the help (as ever!)
I guess moving the wire feeding the tone controls from the wiper to the input should effectively put in into a regular Strat arrangement?
That means I can easily make changes in a few seconds without lifting the scratchplate, and when I'm totally happy with the value I've settled on after a few gigs I can solder the cap directly to the pot at the next string change.
