New unusual retro amp head - circuit suggestions welcome.
4114Effects4114Effects Frets: 3131
edited October 2017 in Making & Modding tFB Trader
Had a couple of hours spare in the workshop today so knocked up this unusual little beauty....
https://c1.staticflickr.com/5/4495/23888410908_d4e4ac3536_b.jpg
https://c1.staticflickr.com/5/4472/37031902004_c5eae59c08_b.jpg
Now I need something retro and funky to put in it.
I'm thinking EL84 for some reason ... maybe AC15 style? Tremolo? Hmmmm.
  • Modulus_AmpsModulus_Amps Frets: 2602
    oh my, think you need to check your square!
    something vintage or obscure would be cool
  • 4114Effects4114Effects Frets: 3131
    Set squares are for wimps. I did all those angles by eye. Look like perfect 90degrees to me ... :-)
  • MartinBMartinB Frets: 218
    It might be fun to go a step beyond the usual tremolo circuits - perhaps something with Fender style Harmonic Tremolo, or Magnatone vibrato.  That would certainly suit the aesthetic IMO.
  • BigMonkaBigMonka Frets: 1784
    That’s so cool. It looks like something that a character from the Jetsons would play. So something space age needs to go in there!
  • stickyfiddlestickyfiddle Frets: 27391
    Whatever it is, I feel like you should include some kind of pedal-controlled delay circuit that can do this:
  • ICBMICBM Frets: 72789
    AC30 Vib/Trem channel with a fully variable speed control and Top Boost tone controls.
    Most AC30 derivatives - including the modern Vox ones - leave out this wonderful-sounding channel, because it takes three valves but hardly anyone uses it... I have no idea why. If I use an AC30 I always jumper the channels so I can blend it in.
  • fields5069fields5069 Frets: 3826
    Maybe a Peavey Wiggy type circuit? :)
    Some folks like water, some folks like wine.
    My feedback thread is here.
  • DannyPDannyP Frets: 1682
    How about an all valve multi-fx?
    Overdrive, Trem (+ maybe some other cool modulation), reverb (with a proper tank)
    And a 'multi-core' cable to a foot controller.
    Like a Peavey Valverb, but built better...
  • bbill335bbill335 Frets: 1391
    It needs a big, drippy reverb.
    It also needs a matching cabinet with the tilt going in the opposite direction :).
  • impmannimpmann Frets: 12694
    Deffo AC30 based.
    AC30 is far too much amp for me. I'm leaning towards AC15 with trem :)
  • DrBobDrBob Frets: 3012
    Drip tray for the left hand end to catch all the beer that will get spilled ?
    Actually, I think a higher powered AC10 might be in order. Looks like a lovely vintage circuit with a great trem. Unusual valves is a bonus - EF86 and ECL82. Anyone any experience with these amps?
    Yes, I had one. They don't sound very good - thin and ratty, like an oversized AC4 instead of like a lower-powered AC15.
    Unusual valves are often a pain in the backside to get good quality spares for. EF86s aren't too much of an issue, but ECL82s are - and they're just a weak-sounding valve anyway, even good ones. ECL86s are better if you must use combination valves.
    If you want an EF86 preamp, build an original AC15 circuit.
    Fair play. Good job I didn't just spend a couple of hours converting the AC10 schematic to a layout ... lol
    Add in an Arduino Controlled programmable tremolo.
