im going to do a revalve in my Genz El Diablo 100 this weekend so I thought I'd just get a bit of advice before doing it!
Im a pretty competent person, I worked for 8 years doing subsea oil and gas survey cable terminations so I'm not shy with my multimeter and the amp had external bias point and trimmer.
im looking at putting 6L6gc valves in, Genz recommend a figure of 0.450 volts but I tend to prefer my amps a bit colder, is there any reason why I couldn't drop that down to say .400v?
Another quick question, which run hotter under usual operating conditions? 6L6 or EL34 ?
Biasing your amp a bit cooler as you suggest will be fine.
6L6s have a higher anode dissipation rating, 30W vs 25W, cf EL34s, so you could bias 6L6s a bit hotter.
In practice El34s and 6L6s are biased pretty much the same.
would lowering the voltage have a significant effect on the temperature?
are there any cons to biasing colder? I'm a preamp gain guy!
The voltage is an indirect measurement of current through the valves.
Reducing the current at idle will reduce the power dissipation in the valve, so they will run cooler and hence should last longer.
If you bias too cold, then in a push pull amp then you get a situation where for part of the signal neither valve is conducting, which does not sound good. This phenomenon is referred to cross over distortion.
I s that 0.4V across a one Ohm sense resistor for all the valves?
Dave.
thanks again @jpfamps
Do it and then have a listen. There may not be a noticeable difference between the two settings. If there is, then use your ears.
For example if it's 10 ohms and applies to one valve then the idle current is 45mA - which is a bit too hot for a 6L6 at conventional plate voltage in my opinion, although it's pretty much dead on 70% of rated dissipation.
If it applies to all four valves then it will likely *not* be 2.5 ohms - which is a non-standard resistor value - so the actual current may be lower, if for example it's 2.7 ohms.
In any case, you can lower it safely as you don't go into crossover distortion - how to tell is simply to set the amp up for a full clean sound and play gently - if you hear odd distortion, increase the current setting until it goes away.
I have found a schematic for a Diablo 60 with 6L6 and it has a 10 Ohm in each cathode and a 10k 'build out' resistor to the test points. I cannot find a bias value. And! This thing is weird! It uses a TL072 as the OP valve driver via a centre tapped transformer. Why? That must cost way more than an ECC8x? Maybe they found 10,000 traffs for bugger all?
Dave.
Treat that as an upper limit and bias anywhere between .35 and .45V and it should be fine.
