hi folks,
just having a look at my mates laney for him as it stopped working at our jam night the other week.
a brief history.
pub, beer, mantelpiece. Vibration , beer in laney. Bang.
fuses changed and all well till the next jam night. When switched on the volume was very low and then nothing. Power light was on but no sound.
got it home yesterday and found the first two valves as pictured.
i put two spares back in and volume was very low and within about a minute those two valves were hotter than the sun.
i've tested the resistors on the valve bases and the ones I can see that look associated on the pcb and they all seem fine.
repair is probably beyond my limited knowledge but any ideas what might be causing the valve meltdown?
cheers!
https://i.imgur.com/1yBllyh.jpg
The Swamp City Shakers
If you're not up for taking the whole thing apart, thoroughly cleaning and drying it - front and back of any PCBs that could have got wet as well as the valve sockets - and probably powering it up with a Variac, it's best left to someone who's done this before.
This is why I don't like amps with top-mounted control panels and/or 'beer traps'...
Yes, this can be a protracted process. We had whole, sq ft TV PCBs with cola in them. The only recourse was a long wash in water followed by hanging in front of the air blow heater in the industrial unit we were in for a week!. The telly mnfctrs would not supply PCBs and so we did not want to write off £300 of colour TV.
Mind you, I did rescue a Mersey Super 15 PCB (Dommy clone) which had suffered in a damp garage. I emptied a whole, large can of WD-40 over the board then left it in a dry loft for a fortnight. Been fine even since.
Dave.
The problem with drinks is the organic matter that stays behind when the water has evaporated...
is possible that beer could of got into the transformer. It's one of those round types wrapped in plastic?
Wash the valve sockets thoroughly with clean water - if you live in a hard-water area, it's genuinely worth using cheap bottled drinking water for this - since the contamination is water-soluble! Solvent cleaners don't always work as well, surprisingly.
Have done that. I'll report back when dry.
In theory it shouldn't happen - the EL84 is a well-designed valve with the high-voltage pins on the opposite side of the base from the low-voltage ones and gaps next to them as well, so shorting directly between pins is largely prevented - unlike the notorious pin 3 to pin 2 or pin 4 (or 6 if used as a support for the screen resistor) to pin 5 failures in octal bases. But put enough beer in and all bets are off…
Also, do the valve sockets have a metal ring/tube in the middle, and if so is it connected to anything? From memory it isn't in these Laneys, but some amps do use it as an anchor for the cathode connection - including some AC30s. Arcing between the HT pins and the edge of the ring on the valve side of the socket is a common problem. I remove the tube from the sockets, which is a bit of a fiddle but prevents the problem.
Worst drink I've dealt with in an amp is orange juice.
That was not great.
The valve bases do have that central pin icbm but nothing to suggest any arcing.
tech time me thinks!
Tech time definitely.
the nasty hum has gone, and the valves have stopped melting.
The only thing I found that was possibly a bit suspect was a globule of solder on one of the cables to a valve pin (v7) that was just touching the cable on the next pin. Wether this had just melted through the insulation and was causing a short or not I don't know. Couldn't see without a magnifying glass and I forgot to check before I put it all back together.
But all good for now!
