its very messy, and will have you in tears, literally. It’s very hard to sand too.
There are much easier and safer methods
Instagram
have a load of thick superglue at work that I tried grain filling a walnut sample piece with with the view I might then top coat it. I did it out of door and the smell is not healthy it was a still day.
then the sanding as said is hard and even on a test piece the dust is horrible you need a decent mask as the stuff is evil.
i love a quick finish but found this stuff just nasty nasty
As for filling grain or small wood dings, Rustin's grain filler is the best thing I've found (not that I'm any great expert in these matters).
I still use it for drop fills - small amounts are manageable
I tend to skip grainfilling most of the time these days, I haven't found one I like.
dings always gets steamed out before the last stages of finish sanding
Instagram
Hmm.. Interesting.. Cheers guys...
Ive only used super glue for binding and for filling in the tiny gaps you get on inlays.. It works well for that..
I think I will stick to tru oil
http://www.rabswoodguitars.co.uk/
https://www.facebook.com/RabsWoodGuitars/
My Youtube page
Instagram
Well I have a spalted top I want to use at some point.. I may try it for that since I know they can be a bit weak so is almost a necessity for those kind of woods (well from what I have read, but haven't actualy done a top like that yet). But I reckon for most woods I will stick with oil...
My Youtube page
wilkos sell a value superglue that’s quite good for this, and much cheaper than proper branded thin CA
Instagram
Ok, cool I will check that out...
This is the top I have
https://i.imgur.com/Mzpc2Ly.jpg
My Youtube page
A few years back it was all the rage on talkbass'es builders page as a fretless fb finish i never got around to trying it though my local home bargain's does some super thin viscosity tubes of SG @ 39p a tube i might grab a few extra and try it on a scrap piece see how it goes
Has anyone ever use the "Massy Finish" my bro who's into bow's and stuff was talking about it a few days ago when i was banging on about how great/fast i though RPC was as a finish,Seems its used a lot in on staves and arrows and is 2 party epoxy thinned with acetone,thanks to photobucket fucking up the net i can only find thumbnails iamges of the results
For Spalt & unstable burls ive used Ronseal Wet Rot Wood Hardener and soaked the pieces i used in a bath of it over night then let it dry on a pin board for 48 hours,it does darken the wood a little but worked well,nasty stuff though so make sure you use it outside and wear a good mask
Instagram
Instagram
