Rebuild a stratocaster copy to tenorguitar
Planning on rebuild a stratocastercopy to a tenorguitar. Anyone know where I can find a bridge.
  • TTonyTTony Frets: 27690
    Moved to making & modding - you've got a better chance of a knowledgeable discussion / reply in there.
    And welcome to theFretBoard.
  • FunkfingersFunkfingers Frets: 14573
    Obvious initial questions that need answering are:
    1) Does the donor guitar have a fixed bridge or some form of vibrato?
    2) Do you propose to shave the neck down or spread the four strings across the width intended for six strings?
    3) Do you propose to run the four strings at the existing saddle spacing for the ADGB strings or set them wider apart?
    If your donor guitar has a fixed bridge, you should be able to fill and redrill to achieve any string spacing you desire using these
  • Its a bridge with a vibrato, Not gonna shave the neck and I¨m going to set the strings wider apart.
