A couple of years ago I bought a Roland GR55 and mounted the standard GK3 controller to my SG. At the time I also bought the GK3 internal kit with every intention of fitting it sharply. However, my woodworking skills are not exactly what you could call on a par with the good folks who do marvellous work here. I can wield a soldering iron, screwdrivers and wire cutters quite merrily, butdespite my good intentions I'm not too hot with chisels, routers etc.
So after prevaricating for a good while, I decided that my Blue Partscaster that was quite happily being a standard partscaster would have some
surgery butchery.
Firstly, I bought a new HH pickguard and routed out for humbuckers. First cockup was not thinking to use my acrylic template to make a second template and somehow, I managed to run the cutter into the acrylic. I think the guide bearing shifted a touch.
I successfully misused a set of assorted cutters to widen the cavity and wide create grooves between the cavity and the jack socket route do so that I could run all the wires round without interfering with the standard jack function.
Thankfully the pickguard covers the bad routing.
I have had a set of Schaller Golden 50 humbuckers since the mid - late 80s and I quite like them. Their mounting screw holes have stripped over the years so I widened the holes a tad and soldered a couple of 3-48 nuts onto the baseplates - result
However cockup number 2: I'd made a template to route a GK3 pickup sized hole in the scratchplate and did a load of successful dry runs. However when doing the cut for real, the router but kicked a little and shifted the template a touch (I was using double sided tape and some spring clamps). It's not too bad but is annoying.
The switch is one of the EYB megaswitches. Positions 1,3 and 5 are wired conventionally with positions 2 & 4 being partially split voicing the screw coils.
I initially mounted the the two huge push switches that came with the kit for the S1 and S2 function to the pickguard as I was wary of visibly butchering the body too much, but I found that they were extremely sensitive and cock up number 3, I didn't realise that my strumming hand goes right over where I'd located them. I'll get a new scratchplate at some point but the bit of green tape serves as a reminder.
I had intended to leave the synth / magnetic switch to be hardwired to synth only, but as I now reverted to using a mini toggle switch for the S1 / S2 function, I put both behind the bridge. I did lots of careful measuring to ensure that they were in a line with and equidistant from the jack socket in a place that was also reasonably ergonomic to use. However.... cockup number 4. When I was doing all this measuring, I'd left the rear cover off, so when I fitted it back on realised that the cover was now a touch too close for comfort.
So a but of judicious filing of the cover I'd made was in order. At which point I discovered that the rear plate was a lot more white than the bit of the parchment pickguard I used. in fact I've only ever bought parchment coloured backplates so it must just be a touch lighter..
The GK3 socket installation was also a touch painful. My (cheap) large forstner bits were really struggling to go from the side through to the jack socket route so I played safe and went up in normal drill sizes and just ran the large forstner at the end and squared up with a jigsaw. Cockup number 5: one of the drill bits wandered a touch so the hole wasn't as central as it could have been, however this means that cooling won't be an issue
The gap isn't visible from the front and looks worse in the pic than in the flesh so I'll live with it.
Here's the final result. It works pretty well all things considered, and in my defence, I know I'm cr*p at woodwork, but I'm going to blame all the wonkyness fairly and (not too) squarely on the fact I wear varifocals and it's completely impossible to trust them to judge when a line it truly straight or not as that would depend on holding my head in one position, looking through a specific part of the lens and hoping that the moon is in the right phase
BTW, I've no idea what this body is finished with, but it stinks to high heaven when drilling through it.
https://i.imgur.com/4tYtzS4.jpg?1
https://i.imgur.com/TE1vVq7.jpg?2
Well done for at least making it all work properly and not look too bad from the outside. I'm not sure it's worse than my original attempt something similar either...
And it does
I've used the varifocal excuse for years with MrsAndyjr1515 to explain wonky shelves and similar. And she doesn't believe me either
Well done - it's not an easy job installing one of those...
But, it's only a scratchplate and I can easily order another and have a second go. TBH the reason I've not done that yet is I'm considering going HSH as it would make it a touch more versatile and I've a reasonable quality single coil sitting in one of my many boxes of bits
Now add a Sustainiac.
The real annoyance I have is that my father in law was a brilliant engineer and had his own workshop where he built fully functioning scale traction engines and the like stuff from scratch. When he died my mother in law offered me my pick of his machines one of which was a lovely milling machine that would have made jobs like this so easy and through not wanting to go through the trouble of shifting it as it was a bit of a beast plus finding somewhere in the garage to house it, I passed on it.
It'd also be cool to put a Sustainer on it.
For GK variants with the strap pin bracket, using this saves further drilling. The downside is that the GK controls will be too far away from the playing area to operate without momentarily ceasing to play.
Given what the S1/S2 Up/Down switches can be programmed to do, it makes better sense to have the Roland momentary press switches than DPDT or DP3T mini switches. I generally use them as performance controls. Patch changing duties are relegated to remote foot pedals.
