Mustang slider switch wiring question?
paulnb57paulnb57 Frets: 3064
edited November 2017 in Making & Modding
The Mustang type of 3 way slider switch, can I wire just one to give bridge/both/neck, there are two rows of four eyelets on the back of the switch......
or is there a switch that fits that will?
Failing that could I wire one switch to each pickup, so that when both are on gives both? I just wat to do away with the phase switching as I find it pointless....
Thanks!
  • ICBMICBM Frets: 72573
    Yes, you can use one switch as the pickup selector.
    Wire it like this:
    1  2  3  4
    5  6  7  8
    1, 3, 6 and 8 to the volume control, 2 to the neck pickup, 7 to the bridge pickup.
  • paulnb57paulnb57 Frets: 3064
    @ICBM you are a star! Thank you!
  • JD50JD50 Frets: 660
    I did the 5.0 mod where I could select the pickups via one switch & the other switch was wired to In phase out of phase and a bass boost.
    http://www.redherring-tonebones.com/mustang-wiring-configs-schematic-mods/
    Nice link @JD50 ;
    Thanks!
